Dynamat? Help
San Antonio, McAllen
Hey guys my fj40 has herculiner in it from po. Should I remove this before I insulate the tub with dynamat? PO says there was no rust issue that he was aware of but there is sureface rust on some of the bolts and i removed some screws to find part of the tub screw holes rusty. Any advice would be greatly appreciated. Also, how should i seal the dynamat to keep the moisture from coming inside the truck and getting to the tub? HELP----- any help would be much appreciated :D
Hi Vandaman88,
I have a fair amount of experience with Dynamat. First a couple of questions..
Why Dynamat? It is a great product, but its ONLY purpose is to stop sound. It would probably be pretty ineffective in a truck such as a 40.
Is your 40 COMPLETELY sealed from the elements? IOW, are there any holes, seams, etc where water can get in from below? I havent seen a 40 that is! LOL! Water underneath the Dynamat will definitely cause rust.
How do you plan to use the 40? Once the Dynamat is in, its pretty much permanent. So hosing the truck out isnt really an option, or rain, etc. ALSO, ANY RUST must be dealt with PRIOR to installing sound deadener!!!!
Bedliner? The Dynamat needs to be applied directly to the metal surface, in order for it to adhere correctly, as this is what deadens the sound vibrations.
Conclusion... I would NOT use Dynamat (or similar product) on a truck such as a 40, unless you plan to TRY to make it into a water-tight enclosed SUV type of vehicle. Even then, the truck is inherently so noisy that you most likely will never notice a difference. Its expensive, as I spent over $300 just to do the cockpit of my 72 Corvette.
Sounds like alot of work and $$$ for minimal (if any) effect.
My $.02!!
Hi Vandaman88,
My $.02!!
Mako my 40 definitely is not sealed completely. I was kind of hoping to seal it so I could protect the body. I thought dynamat would be good to keep the heat from the engine and transmission as well as the sound and vibration from the tires from coming in. What else could I do to solve these problems and try to keep rust out at the same time? Man I guess I need to think about this some more. I already have all the dynamat on its way :doh:
Vandaman88,
Hi, I am makoshark72...I had forgotten about my old "72 Shark" name, and I'm resurrecting that name.....sorry for any confusion.
Dynamat, regardless of what others may or will tell you, does virtually NOTHING for heat. The foil backing may help a LITTLE, but its purpose is for SOUND, not heat.
I will put money on, IF you proceed to install it, you PROBABLY wont notice much, if any, road noise reduction, and you will notice NO heat reduction.
For heat, go to Home Depot and buy a roll of Reflectix. It will cost you around $20, and you'll have enough to cover the entire interior of your FJ40. You will need 3M spray adhesive to stick it to vertical surfaces, but ALL you need to cover is the tranny hump, the firewall area of the footwells, and the floor over the exhaust pipe. There are no more heat sources in your FJ40. Reflectix does absolutely NOTHING for noise!
Since you have the Dynamat coming, you need to decide what direction to go. Dynamat is really designed for an FJ60-type truck, where you have an enclosed vehicle that doesnt leak, that seals around the doors and windows, and that offers more of a "civilized" ride. There you will definitely notice the sound dampening qualities of Dynamat!
I actually think installing it in a 40 will hurt any resale value, as most EVERYONE looking for a 40, will want it either original, or without the extra weight of Dynamat, or without the job of removing it in order to to use the 40 the way it was designed to be used...
I am not a big fan of spray-on bedliner-type materials, lots of guys use them, and for sealing up the truck, I think its hard to beat a well done spray-on sealer. Problem is, once on, its a HUGE job to get it all off.
Bottom line......I would ditch the Dynamat idea (in a 40), have a reputable shop seal your truck with a bedliner-type sealer, and move on. The sealer will most likely do just a good a job dampening road noise as the Dynamat, and waterproof you at the same time!!!
Good Luck...
BTW, I want to Dynamat my 90 FJ62, so IF you decide not to use the Dynamat, drop me a note.
Rob
I can't speak for dynamat, but I did notice a decrease in heat from the floor pans and the tranny hump after applying a bedliner to the inside of my 40, which only means, your 40 was even hotter (if you can imagine) before the PO put in the herculiner.
Personally, a couple thick floor mats and the bedliner work for me, but that said, my fj is by no means show quality, I don't have a hard top (loud), and I like the ability to hose down the inside. If you want a quieter, more comfortable interior and have the time and dough, go for it.
What about putting down a bed liner type material to seal the cruiser and steel of the tub. After this putting in dynamat? Would the dynamat still be as effective if not applied directly to steel? Also would it be possible to line the dynamat with a marine type carpet once installed? I was thinking of using that to cover up the dynamat. Also if i did install dynamat could i place the reflectix over it in crucial spots? I have heard of mixing ceramic beads with paint and adding rustoleum type anti rust products to the mix.
Ok I think this is what I'm going to do:
1. Clean up all rust
2. re-weld where necessary
3. re clean up all rust
4. Buy ceramic beads to mix with rustoleum latex paint, paint inside of fj40 with this "lizard skin" alternative
5. Research whether or not I should put an epoxy bedliner
6. Lay dynamite over lizard skin paint. Should I then coat dynamite with epoxy bedliner?
7. have the interior lined with marine carpet
Should I top pff dynamat with a bedliner or maybe another layer of lzard skin or just stick the carpet right on top of the dynamat?
How does this sound? Does this order of events make sense?
Wow, this has gotten complicated!
As far as spray on sealer, I was referring to "bedliner-type" products...
No, I would NOT install Dynamat over a "bedliner". If you insist on using the Dynamat, apply it directly to the steel for best results.
If you insist on using Dynamat, make damned sure there is NO PLACE for water to come in from below and get under the Dynamat.
If you insist on using Dynamat, I would simply install a nice heavy marine type carpet over it, no need to use spray adhesive, just lay the carpet on top of the Dynamat.
No, I would NOT spray anything OVER the installed Dynamat, such as lizardskin, etc.. You want to , however, install the Reflectix over heat source areas, as I mentioned, using just a very little 3M spray adhesive on the vertical areas..
Honestly, I would ditch the Dynamat idea. Get it "bedliner-ed" and have fun with it!! Results will be the same and MUCH more durable and waterproof.
I will buy your Dynamat.
Dynamat
Installed dynamat in my FJ40 about a year ago and it does quite the truck down quite a bit. It also seals all the holes in the floor, so it takes care a vapors as well. Much improved driving experience.
In terms of heat, my bare feet don't burn anymore when I drive in the summer but I also put down a carpet kit over the dynamat.
I am not doing any water crossings and don't really see how some rain will get under the dynamat - it creates quite a seal. I also had a spay in liner so it wasn't bare metal.
I have to agree, I don't know how you would remove the dynamat once it is installed. A heat gun and a good scraper I would imagine.
For me this was good upgrade.
See this link for details https://forum.ih8mud.com/40-55-series-tech/237724-dynamat-sound-deadening-completed.htmlhttps://forum.ih8mud.com/40-55-series-tech/237724-dynamat-sound-deadening-completed.html
Alright this is my plan of attack for anybody who is interested... first i am having the tub taken off the frame. I will then have all the rust killed under the body and on the interior. I will have it sealed with an aluminum type seal. Next I will have the interior and underside of the body sealed with a primer. I will then have the underside and interior sealed with lizard skin. Next i am going to put dynamat into the interior. To ensure that i have maximum insulation with combined strength i will then seal the dynamat and lizard skin with line-x on the interior and underside of the frame. Any thoughts......
as someone who is currently removing a "bedliner type" material from my FJ40, i would not do anything like it to mine.
The stuff in my 40 looks like plastic dip. it is very thick in most places. It looks like it was very professionally done and done early in the truck's life. but i am pulling it because there is rust under it. real bad in places. it is a real pain in the ass to remove, also.
I would fix the rust and paint it. Then get reflectix or something for the high heat areas and use it under good floor mats. Keep everything removable. Water is going to get into your rig.
I realize that this isn't the greatest solution for a number of reasons. but i think it is the best long term solution. And looks nice and stock.
Old post but I thought I'd also agree that removing bedliner from the inside of my 40 has been a total pain in the ass. The bedliner was rolled/brushed with wanton abandon and there is surface rust under the majority of it. Might be good for someone in a dryer climate but here in the PNW, it doesn't look like a winning solution.
