dwell angle
Cairns, Far North Queensland
1982 FJ40
I have just installed my dizzy and have set the points gap as necessary.
My non FSM gives the required dwell angle to be 41 =/- 4 degrees. The information with the gauge indicates that between 30-40 is appropriate for a 6 cylinder.
The gauge reads 36 degrees which is outside of the scope of the manual but in the sweet-spot in accordnce with the gauge info.
Should I change the gap to suit the manual or leave as is.
What is the significance of a smaller dwell angle?
Thanks in advance
Justin
Measure the dwell angle. If it isn't in the middle of the allowable range (say, 41 degrees when the range is 39-43 degrees) stop the engine and move the point gap closer to raise the dwell or farther apart to lower it. Keep doing so until the dwell is correct. Dwell angle has always been set by properly adjusting the ignition point gap. Your points gap was derived by engineers to approximate the dwell angle, but individual point sets can vary considerably in their mechanical and electrical characteristics. The only way to properly set up ignition points is with a dwell meter. Since dwell is measured by camshaft rotation and the camshaft runs at twice the speed of the crankshaft, for every two degrees of dwell an ignition is off from its proper setting, the engine's timing will be off one degree. The dwell time, normally defined as the( degrees of rotation of the camshaft during which the points are closed) Too little dwell and the coil doesn't have time to charge fully. Too much dwell and the coil can bleed off some charge, causing a weak spark, hesitation, low power, misfiring, pining, and a number of other conditions are symptoms of incorrect dwell............
