Dumb Ignition Timing Question
MD 'Burbs of DC
My previous distributor had two "screws" protruding from the side to set the timing. My new distributor, with electronic ignition, has no such "screws" that I can see. How do I adjust the timing? Sorry for such a dumb question. Thanks. If pics are needed I can post.
You turn the body of the distributor and after it is set, tighten the clamp bolt.
If you have replaced the distributor, you meed to make absolutely sure that the end of the distributor is properly seated in the oil pump drive slot or you could ruin your engine in 1 minute of running time.
Is that the sorta-not-quite-easily-accessible bolt underneath the distributor that is oriented parallel to the ground? Thanks.
