Duel locker
Hemet, CA
I have an FJ-40 with a locker the previous owner called a “duel locker”. I am unable to locate any information on it and need to remove it. Can’t figure out how to get it apart so I can get the c clips out.
I believe that is a Torsen worm gear locker. In my research years ago it supposedly does not hold up to large tire and hard wheeling. What ever you do do not try and take it apart. If you decide to sell it let me know.
I have a set in a very old Land Cruiser. These do work with a semi floating rear axle with C clips. Mine has special hubs on the back axle with press on bearings to hold the inner axles in. Newer axle could use a full floater rear axle.
Made in the USA, date back to 1958. The original inventor cut the original worm gear in his own shop. Hear year ago these were very costly to make because the technology wasn't to cut the sharp angle worm.gears. Toyota has been using them since 2003 in transfer cases. Believe it's Eaton who makes a combination Torsen/E-locker but not for the Land Cruiser.
I put one in the front axle of very first 40 back in about 1979 or so. IIRC it was re-machined from some other application to accommodate the Toyota ring gear. I liked it, but that was back when 33" tires were pretty much the standard.
I do remember specifically that the instructions noted not to be concerned about the metal shavings you would find the first time you changed the gear oil. o_O
I agree that a 37" or larger tire might be problematic.
Looks like my axle was converted to full float with bearings and flanges on the tire side of the axle and no c clip on the third member end
Could still have one in the front. Unlike limited and Lock-Right type auto locker when the tires are off the ground and spin one wheel the other one rotates the opposite direction like a open diff. I ended up driving up a hill with loose gravel and had someone verify both wheel kept moving at the same speed.
Mine has a custom hub and pressed on wheel bearing. I remember the the part number for that bearing actually had two different sizes. Ordered a pair. When they came in they slipped right on the axle. Returned them and continued to hunt for the correct ones. One bearing business had the correct one sitting on a desk. Same story in reverse. Only it had happened years before and they could find another. Size was right around a 1 1/2".
the front has an ARB locker and the back will have one soon. Ran into a figment issue with the air distribution ring not seating all the way leaving the o ring partially exposed. Working with ARB now
That’s interesting...I assume the BL is dialed in? I’m curious if the carrier bearing didn’t get seated all the way down??
The back lash is dialed in and we verified the bearings were seated, also have a great pattern on the ring gear check
