Can anyone tell me if the solenoid on the dual tank model is just a pump or an aoto filler.As i push the button in the cab and fuel goes everywhere.I had a look and looks like there are hoses missing from the solenoid.Can anyone post some pics or explain how i can fix this problem Ben.
It sounds as though you may be missing some plumbing. Most of us are stateside and as such we do not have much direct experience with subtanks. Some of us, myself included, have Aus-spec subs in place but we do not have OEM plumbing.
AFAIK, the solenoids (there should be two of them) switch between the sub and main tanks in the main fuel delivery line to the motor and in the return line from the motor.
When the switch on the dash is set for main tank use the solenoids change to allow fuel to be taken and returned to the main tank. When it is switched to the sub tank the supply and return both go to the sub tank.
If you have fuel going every where and have hoses missing you need to work out which hose it is and which solenoid it is.
I have a diesel cruiser (see my sig line) but IIRC they are pretty similar.
Let us know how you go. I might be able to crawl under my rig and take some photos if you want.
First post guys - happy to contribute and hope it helps!
In the UAE where I live, most LC80s have dual tanks; Ben, it's not the solenoids if there's petrol pouring out, it's something wrong with the fuel lines - the plumbing hardware, not the electrics. When you engage the switch it's doing it's job and switching over.
Park over some sand or your neighbour's flower bed, give the switch a go, switch it back, and then go have a good look where it's coming out from. Put out yer ciggie first, OK?
Probably something simple like a cracked/disconnected hose.
No worries guys looks like the outlet of the solenoid is snaped off so i will track one down and replace it i suppose.But still the drama of finding where the hose goes as previous owner must have removed the fuel line for some reason.thanks for replies folks a bloody top site ya,s got here.
My 80 is set up with an Aussie subtank, parallel fuel lines, and switching system. This is originally from MAF. I have had no trouble with it working, but am not sure if it is the same as the set-up you have. Does yours switch the gauge inputs as well as the fuel feed?
