Dual Battery Setup with DHP Problem
NW AR
I have a National Luna dual battery setup with a group 34 DieHard Platinum starting battery. The auxiliary(2nd) battery is a Die Hard marine deep cycle. My issue is that I occasionally go out to start and the voltage is low enough that it won't crank. After a jump or charge it runs flawlessly and it may go weeks without issue. The alternator and both batteries checked out as "good" when I had them tested. Does this sound like a bad battery or something else?
Does it drain both batteries or just the start battery?
But, I'm thinking parasitic drain too. Measure the load with everything off. Likely culprits: stereo equipment, aftermarket car alarms, even the Nat Luna dual battery thing (there seem to be a bunch of failures of those).
Sounds like the DHP is on its way out. I had one start to go out after about 4 years. I nursed it along to almost 6 years. I had Slee style dual battery system and never got stuck anywhere. Same symptoms you mentioned that progressively got worse to include suddenly shutting off once while I was driving. It started right back up but that was the last straw. I did end up changing the second battery at the same time so they are both matched up again. Didn't have a Sears in lower Alabama and not sure I would buy them again so I ended up with a couple store brand gel batteries from advanced auto parts.
It drains to the point where it won't start off either battery. The Luna gauge shows about 60-70% on the main and more on the secondary. But it won't crank and if I override it(use secondary batt)then it draws everything out of that battery too. I'm just stumped, but guess I will do more troubleshooting to see if it is parasitic drain.
My guess is your National Luna is bad. Lots of web lore about National Luna dual battery systems crapping out. Disconnect it, and see if you still get the same problems.
Unfortunately, bad batteries can also be the cause of all of this.
Or, if you have a meter, just figure out where you have loads you don't know about.
This. If you search around on expedition portal there is a thread about National Luna failures.
I wouldn't write it off just yet, but it seems likely. If you contact Paul May at Equipt he will more than likely help you out.
I just read through a lot of info @ Expedition Portal and I'm definitely not the only one with issues. Wonder if I'd have the same issues with a group 31 lead acid battery or something other than the DHP?
I don't think the battery type makes any difference. A battery is binary and either good or not. It's easily tested. If it's not fried, you *may* be able to recover a bad battery with the proper charge routine.
I personally think the "desulfating" chargers make a positive difference. Plug your truck in if it won't be used for a few weeks. I like the BatteryMinders but there are other brands. You want bulk/absorb/float charging profiles.
Those DHPs sound like nice batteries, but they are seriously $$$. You would want to be sure everything else was in good form before running those. Me personally, I run a cheapish starting battery and a Costco Marine House battery. No problems. I gave up on expensive AGM batteries after a bunch of Optima failures-I'm done with those.
I only know one other person with a National Luna dual battery system and it died on a trip to Utah. Based on my experience only, I can't recommend. I've had good luck with Hellroaring(6+ year experience), and recently Blue Sea ACRs (which based on price and quality are a deal).
