Ok. I'm under a time constraint. I need to get my dual battery system working tonight because I'm going to be out of town over the weekend and need my fridge/freezer to keep food cold. I've been running the fridge off of the house battery all day then charging it at home at night. This is
and a pain. Plus I won't be able to do that over the weekend.
Here is what I have. I want to make sure I have everything so my house battery can charge off the alternator and so I don't start a fire.
(1) Starting Battery - Interstate Batteries MTP27 810CCA
(1) House Battery - Interstate Batteries 27MXHD Deep Cycle
(1) Blue Sea SI-ACR Automatic Charging Relay
(10') 2ga Welding Wire (red)
(10') 2ga Welding Wire (black)
A bunch of heat shrink and connections (the hammer on crimp kind).
What is the easiest way for me to set this up? I don't have a ton of time tonight so appreciate your help.
My limited electrical knowledge tells me I need a 150amp fuse at each positive terminal for the batteries. And to upgrade the ground from the negative to the engine block to the 2ga to match the other. Is this correct?
And does anyone have the skills to spell it out in a neat diagram? When I have more time I will add a battery switch and my solar panel but don't have the time right now, unfortunately.
Thank you al for your help!
and a pain. Plus I won't be able to do that over the weekend. Here is what I have. I want to make sure I have everything so my house battery can charge off the alternator and so I don't start a fire.
