Will Van
GOLD Star
I am running the positive and negative cables for my dual battery setup on my '93. I have a question about grounding the second battery. I know the OEM battery grounds to the engine block. Would it be OK to ground the second battery to the aluminum head (instead of the block) where my PAIR valve used to mount?
I will also ground the two batteries together. Does anyone have any suggestions while I'm doing all this wiring?
Should I also run a couple of extra grounds to the body and frame? Can you really ever have too much ground?
