1980 FJ40, front disk with rear drums.
I was adjusting the rear brakes tonight and had an issue with one of wheel cylinders. The adjusting nut seems to be frozen to the adjusting bolt. Can only move the adjusting nut a little bit as the adjusting bolt is held fixed by the brake shoes. Anyone run into this before? Any way to free the adjusting nut without having to pull wheel cylinder off?
Second question: I have read the adjustment procedure and understand that you move the adjusting tool away from axle to expand shoes. Just to make sure I fully understand, If I am adjusting the wheel cylinder on the driver side closest to the front of the vehicle (adjusting nut is on the TOP), to expand the shoes the nut needs to turn counterclockwise when viewed from the top of the wheel cylinder, correct?
Thnx
Thnx
