Drum brake conversion questions
BC
I have a 75 FJ40 that has the front drum brakes. Currently has stock rims with hubcaps. I have a 79 BJ40 front axle complete. I have read the FAQ on drums but most of it talks about using mini truck parts. I just wanted to hear from someone that has done the conversion before using the parts from a newer axle. Will I have to grind any birfield parts? Will my rims still work? I have a knuckle rebuild kit as well, hoping to swap over the knuckles outwards basically. I attached a pic of my rim and the newer axle.
Thanks,
Jeremy
Swap the BJ40 axle complete, save yourself a bunch of work. If the rebuild is for the '79 axle knock yourself out on the rebuild. You'll need to run a spacer to clear the caliper.
I'm sick as a dog right now so I hope I got everything right.
Could be a different gear ratio Dick. With a BJ maybe not, but should check first
That’s what I get for answering when I’m sick. Could still swap out the third member since he’s rebuilding the knuckles.
The 79 is a 3:73 and my originals are 4:10. If I have to tear down the axle anyway for the axle seal kit would it be that much more to use my original axle? I am just concerned on how the birfields fit as I believe they are different?
How big of a wheel spacer would it need?
Thanks for all the info guys.
Jeremy
1. There’s tons of threads on grinding out the knuckle balls to fit the birfs. No biggie there during an overhaul.
2. If your rims are welded, you won’t need spacers.
I’m not exactly sure when the transition to large pattern birfields happened. I know 76-78, at the very least, has the same small pattern birfields as you original 75 axle, but got fine-splines instead of coarse.
I think 79 may have been the transition to large pattern but you’ll need to tear down both axles either way - it should be easy enough to measure. You might even be able to tell from the knuckles (later knuckles were bigger).
If you get lucky, you might have small pattern, fine spline birfields in the 79 axle you could just plunk right into the 75 axle.
I did the conversion with FJ60 birfields and knuckles - for what it’s wirth, the grinding wasn’t a huge amount or super difficult.
If you have riveted stock rims, they won’t fit over the discs. But, as Dick mentioned I think you can run a wheel spacer to get the clearance, or, find later, welded rims.
