Dropping Fuel Tank
Hot Springs
Is there a trick to removing the fuel tank on 80 HJ 45 , it almost seems like the cab needs to be raised 8 inches to remove it from its cradle , any past knowledge out there
I'm assuming it's similar to a 40 of same year. it can be taken out without removing the cab
empty tank, remove the straps and skidplate, disconnect fill tube, whatever vapor recovery tubes, fuel guage sensor, fuel pickup and return. and driveshaft
tank can now be wrestled out, it needs to drop down and then slide out to the side
Once loose I would try and move it to one side then let if lower on the other. This is how I've done it on my FJ62. I also use a cheap Harbor Freight transmission jack. The scissor style that sells for around $80.
Razorback,
As with a lot of repairs, you'll struggle to wiggle the thing out of its location, you'll persist, and finally get it. But when it comes time to put it back up there, trying to remember which end goes first, and how far, and in what direction, it'll be a royal pain. I've only done three of those later tanks, followed my notes, and still don't look forward to it.
BTW, in addition to pulling the sending unit, look at your drawpipe for corrosion and possible repair/replacement before you reinstall the tank, or you'll be pulling the tank out again and cursing all the way. Not that I would know !
Ok thanks , this is a diesel tank and the cross support is what’s holding it from dropping , I read on a past post they removed the drive shaft and jacked the rear up and dropped the rear spring on the passanger side , not sure how that would help
dropping the spring may help on a 40 as its shorter than the 45. not sure how that would help you.
