Running down the road Sunday in my 1962 FJ40, the truck started shaking a bit. I was asking my son who recently started driving if he had hit any curbs when the noise changed to a metal clanking on the road and then BAM. I turned around to see our driveshaft skidding in the middle of the road.
As it turns out, it looks like the bolts came out from the back side of the rear drive shaft. Then it finally fell all the way off. I took off the yoke (4 nuts), put it in 4WD and drove it home.
Now, what size bolts are necessary to hold the u joint on the rear differential? Should I replace the drive shaft and if so, from where?
I remember reading somewhere that a person should check u-joint bolts occasionally. I guess I'll believe that now!
Thanks
Thanks
