STILL restoring my 85 FJ60. Bought rust free frame and body 2 years ago and have made slow progress! Moving nearly everything from my rust filled 85 60 to the rust free. The "newer" truck has its gas tank, and it looks like there is less than 5 gallons in the tank that has started to turn and smells like turpentine. Removed sending unit and it looks as if there is a fine layer of crud in the bottom of the tank. I started this journey as a newbie but have gained a novice ranking now. Gas tank work is new to me so I thought I would turn to the experts. Considering options:
-On a scale of 1-5 (5 is a real PITA) how difficult is it to drop and reinstall gas tank by myself? Anything to watch for that is not in the FSM?
-Thinking of not dropping it, draining it, then using power washer through sending unit hole to spray out the crud that I can (with drain plug removed), drying out the tank, and calling it done. Thought I would need to buy a couple of fuel filters and change them out frequently.
-Another possibility is dropping it so I can get st it better with power washer (1-5 question may influence this).
- With a little help I pulled the engine and tranny from the rust bucket and put it in rust free. Maybe I'm being a chicken s**t with gas tank.
As usual, any and all advice from the experts appreciated!
