Drop brackets with coil spacers?
Peachtree City, Ga
I purchased a set of 1.5 inch Metal Tech front coil spacers and I'm trying to figure out whether I need the Man A Fre drop brackets or not. My 80 has an OME 2.5 lift (heavy's up front, medium rear).
For you guys with the coil spacers how does it ride, flex, and handle? I'm looking to bump up the tire size to 315 A/T's. Pictures and reviews are welcome, thanks for the help!
I think the ride with a spacer on top of the spring should be almost identical to the ride without the spacer. It's almost like a body lift, as far as ride goes. As far as caster correction, heavy springs plus a 1.5" spacer should give slightly more lift than a "J" spring. To get your caster to spec, you'll need more than correction bushings. You could replace your correction bushings and get caster plates. You could add the drop brackets from Manafre.
Do you need drop brackets? No. You have at least two options. Plates or living with caster that is out of spec.
I'm betting the most popular replies will be "search is your friend" or "measure your caster, and correct from there". I'm going with the less popular answer. "Drive it for a while, and see how it feels."
Ditch the spacer. 315's will fit fine with the heavy front springs alone and you are opening a can of worms with the spacer + heavies.
Your caster is probably low already with the OME bushings and the heavy springs. With the spacer you would either need to switch to plates (which would probably necessitate a dc shaft in the front), add the drop brackets (which would potentially create a mismatch of driveshaft angles that you can't correct without a double dc shaft), or add 3 degree caster bearings (which would require a knuckle rebuild and you end up with smaller trunion bearings)
Caster is just one issue with that much lift. You will also need longer shocks, extended brake lines and sway bar drop brackets. The metaltech spacers will space the bump stops down so at least you won't have to address those.
