Driving Without Rear Driveshaft?
Russia, far east
Stupid question, but I didn't find a good answer, Driving Without Rear Driveshaft, is this possible?
I'm just trying to find the reason for the strange clunk after transmission shifts from R-D
Changed left/right cv axle
Greased spider bearing, driveshafts
Changed fluid front/rear diff
No luck 😞
You can remove the rear drive shaft and then lock the transfer case. It will steer funny.
Yes you can. @Fisher23 is right, it’ll drive strangely but it will work.
Without the rear shaft, is the clunk gone? It sure seems like that gear lash would clunk pretty good.
Yes, without the rear driveshaft, not a loud clunk but slightly "thug" with CDiff/off, with CDiff/on No clunking no thug at all, completely silent, but except for whining appears during switching trans. I also can clearly hear a whining sound (+ clunking) when shifting trans with both driveshafts on their place.
I also have same issue, but my 200 is still working well. Even my old prado(1999) have same issue, also working good.
