Drivetrain Thump
Orlando, Florida
At low speeds if I lift off the gas I often get a thump or clunk which sounds like its coming from the drivetrain. My old Jeep did the same but I just kind of ignored it then. My U-joints and slip yokes are well greased and I can't detect any play on the drive shift assembly.
Any pointers would be good.
Sounds like my situation.
THUMP!
Check your pinion bearings If you already haven't done so. If you have not checked your front wheel bearings recently do that as well, parts could be slaming on your spindle. Unlikely but worth a check. Good Luck..! :)
THUMP!
Your sure sounds like mine but I only get it a low speeds. It's like one of those trailers with badly adjusted brakes when the trailer body rides the tow bar and rams to a stop. Hard to describe.
That is a damn good analogy!!! Are you sure it doesn't do it @ faster speeds? Read my description & try it & let me know if it for sure doesn't do it at higher speeds.
