Drivetrain bump when starting from dead stop.
Beaumont, Texas
Website
www.marklowimagery.com
This has been going on for a while now and hasn’t really gotten worse but I’ve been trying to figure out what is causing it so I can correct it. After coming to a stop at a light, when releasing the brake and accelerating, there is a bump in the drivetrain. I don’t usually get on the accelerator hard primarily because it hits harder so I just ease off to prevent it. Now if I come to a stop and then put it in neutral and then back in drive, there is no bump at all when starting. Also, if I put it in neutral and coast to the stop and then put in drive, there is no bumping when starting off. It’s almost like something either in the transmission or the rear diff that is not disengaging when coming to a stop normally. By switching to neutral and back to drive, it seems to release or something so that the bump does not happen. Just wondering if anyone has an idea what might be going on so I can discuss it with my mechanic to try to resolve this problem.
Thanks
check the slip joint on the drive shaft, if its dry it can stick and cause a clunk as well
It seems like in the past when I grease the slip joint on rear driveshaft, it went away. I might try that but just don’t want to put in to much and cause it to bind. I’ve heard best way to grease that joint is to take it apart and apply grease to the spline teeth. I know it’s not bushings since I’ve just had all 28 or so bushings replaced with Toyota OEM. Hoping it’s not slack in pinion since that’s all new with 4:88.
id just use the grease fitting, 7-9 pumps if its dry 1-3 if its serviced regularly. if you overfill it you can always take out the grease fitting, unbolt one end of the shaft and compress the slip joint to squeeze some out. it takes a lot to overfill the slip joint
Just put in two to three pumps at a time and watch the slip joint.
You might see it shift a little as the grease fills the splines.
You don't want it to extend in length from adding grease.
A few pumps should be enough to make some difference.
I do have this exact problem. I have new u-joints and cleaned out, re-greased the yokes. The problem goes away for a week or so after a re-grease (no not overfilled), then it comes back. My guess is there is some pitting on the yoke after PO running it dry too long that makes it bind and releases as you come to a stop.
In addition to this, my shifter moves a bit while going thru bumps which makes me think that the driveline is transferring load somehow. Makes me want to get new driveshafts.
Also check your motor and transmission mounts, in addition to all the above points. I changed mine recently and no more bump sounds.
Mine has been doing this ever since I installed my lift.
It goes away for a few days after greasing, then it's back. I'm guessing I have a worn area in the splines that is a ledge it is catching on until it slips past. Due to the lift, it rides in a different location, so now I notice the driveline shift.
I, too, have all new OEM bushings in all of the suspension. Also have a new transmission mount. Have the engine mounts in the garage, not installed yet.
Feels like a new DS may be in order.
Also check your shocks. If the nut on the top pin is loose, it can cause a thunk as it loads or unloads.
^^^^^ I second this. Happened recently to me as well. This was not the nut to the shock but instead one of the two bolts for the mount to frame was loose. Clunk over bumps etc.
when it gets warmer around here i plan to setup a camera underneath and hopefully i can see exactly where this sudden driveline shift is. It's one of those things that constantly bugs me but never feel like i need to fix it right away.
please let us know if a new DS fixes this if ever you come around to it.
Rear drive shaft slip joint. Pump it only a half dozen times though. The splines and the seal are so tight grease in there can not easily weep through. So it can hydrolock and damage your center diff. Pump 20 pumps, then back down your driveway to a bump transition to the street and you just hammered the crap out of the diff case, which is not designed for a longitudinal load at all, thus the slip joint. We should have this in a fixed thread of "Things you can do that will damage your 80." Have a shop grease it with an electric grease gun up in the air with the shaft fully extended (and they fill it this way), then drop it to the ground is a recipe for damage. If your center diff is noisy this has probably happened to you.
Well by just adding grease to the slip joint via the fitting, it completely solved my problem. Thank for everyone‘s suggestions as I was thinking worst case senerio. Just need to remember to grease the drive line at regular intervals before it gets to that point. as for hitting all the grease fittings on the u-joints, including the front DC, I can’t seem to be able to get to them all because my grease gun fitting is to big or long. Maybe if I supported the truck by the frame and let the suspension drop some, it might open up the angles on the hard to reach fittings in the center. other than that, I guess I would have to remove the front DC shaft particularly to be able to get all the fittings. Maybe there is another small grease fitting for the gun that I’m not aware of.
...Maybe if I supported the truck by the frame and let the suspension drop some, it might open up the angles on the hard to reach fittings in the center...
I get the same driveline "clunk/bump" and it is indeed the slip joint. Just keep it greased regularly and it is gone. Additionally, the zerk on my rear u-joint on the rear shaft is only accessible with a standard grease gun if I put the suspension at full droop (stock height suspension). Try the droop and it changes all the angles and zerk accessibility.
I use a needle tip in the grease gun to reach the rear zerk. Depress's the ball and injects grease in one motion, need to hold the needle to seal, so an extra set of hands to run the grease gun helps.
Amazon product ASIN B000N321UQ
This is what mine is. I hold the end with one hand, and run the gun with the other. Push the cartridge against the ground.
