Driveshaft vibration
canada
Hi guys ... I have been chasing a vibration for a while and found this....
Possible cause you think ?
Driveshaft seem (is) twisted of a few degrees ....
Sorry for the mess .... Again ...
check to verify that it's not out of phase
believe me I did ahah , had some other yokes to try on it too and they are all like one spline off on either side
Like the diff angle vs transmission ? I can measure them , they were good last time I checked (when I did the H55 swap)
The front one relative to the drive flange on the transfer case, and the rear one relative to the pinion flange. You want both of these to be opposite but as close to the same as possible. If they're more than degree or two off, you will get a vibration in a certain gear and rpm.
This example is from my 40, but you can see the idea.
angles are ok , so ... I will make another driveshaft with the yokes clocked correctly and see if it help ...
this is not a big twist but I fell like this is why I get vibrations a certain speeds...
Ended up doubting my angle measurement tool... So I measured again tonight with a digital one ...
Got 86 degrees on both flanges and the driveshaft sit at 7 degrees .. so no issues there .
Kept looking and found that my front joint was toasted ... Less than 1000miles on it and no new spare ... Took an old OEM one and cleaned it. The vibration is gone.
I assumed the new parts were good ... No more Moog for me ....Disappointed almost every time .
