Driveshaft Phase Vibrations Gone Success!!!!
Got my DS back from the shop. Put it in and BAM!! No more vibes! I replaced the U joints with OEM and still had vibes. Checked the phasing and it is correct as per the FSM. Check out the weights he added in the photos. There were 2 weights on there already from the factory> The ones in the photos were added by the machine shop. I highly recommend the guys at Bergers Machine shop in Hagerstown, Md!
Ok guys. I replaced my rear ujoints with OEM this weekend. still having vibes. I have searched and read and read and searched. My questions are
When it is discussed to rotate your driveshaft 180 deg are we talking the whole shaft or splitting the two halves and rotating 180?
When I removed it I did not sperate the 2 but I'm not sure what the PO may have done. I put it all back together the way it came off. both flanges are tight with no play. Iam not feeling any issues when rotating the flanges. no crunching or binding. no leaks either.
Does someone have pics with specific detailed instructions?
I called a driveline shop today and will be taking it in for balance if I cannot resolve this by rotating the shaft.
Again should I rotate the entire shaft 180 or just one half of it?
