Driveshaft swap
Godwin
Resident Herpetologist
Alabama
Rear driveshaft on the 80 was shot. The zerk fitting for greasing the slip joint had been snapped off before I purchased over two years ago. I knew I needed to correct this but never did and because of a lack of lube the slip joint developed some extreme slop.
Today I dealt with the issue by swapping in a FJ62 driveshaft. I have a stock height OME suspension so no lift on the Cruiser. Flange to flange measurement with the Cruiser sitting on the ground was 96 cm; I throw this in just for reference. Side by side the 80 rear shaft was 2 cm longer than the FJ62 shaft with the difference being in the length of the main tube - 62 cm for the 80 shaft and 60 cm for the FJ62. Flange patterns between the driveshafts are identical. Put 200 miles on this swap today with no problems.
I have had this driveshaft lying around for years and I think it is a rear FJ62 shaft but I am not certain, so could be a front.
