driveshaft part??
tunica, ms
the driveshaft shop can not find the part i need. it's the upper flange that bolts to the parking brake drum. it's a cv joint driveshaft, so i guess this flange is also part of the actual cv joint. anybody know where i can get this part?
I may be wrong, but I think if it's a CV joint on there it's a non Toyota shaft. If that's true the new CV joint piece must be drilled to match. Probably a Spicer part that can be found at most drivetrain parts suppliers.
i talked to the shop again and he's saying something about the pilot may not be right, so he wants me to take the parking brake drum to him so he can check it, or something like that. i don't see why you can't just rebuild a cv joint. when they wear out is the whole thing shot? i mean, does it actually wear the metal part of the joint out? i thought you just put new ujoints in it and that was all, but i guess that's not the case. i'm just tired of waiting on it, i guess.
There is a ball and socket gizmo in the center of the CV joint. You know the one that's real hard to grease even when you have the right tool and know it's there?
That's the part that usually goes on them because of lack of lubrication. If it's been dry too long then you need new parts. :frown:
missipboy said:
can you replace just the ball and socket thingy, or do you have to replace the whole cv joint??
I believe the socket part is machined into the two halves of the joint. If it's wallered out and causing a problem then I would expect they have to be replaced. Maybe it's like a bearing race that can be replaced. Not sure cause I've never had one apart. I just know it's in there, needs lube and must be tight for the CV to work right.
The first thing to determine is what CV is it? Toyota mini/FJ60 or some Spicer thing? My experience is the same as Sdandiel. If truely the "upper flange" as you call it is bad it may be because they fawked it up getting it appart. There is a real trick to R&R'ing these CV, or double cardan joints. See my first link.
http://www.4x4wire.com/toyota/tech/cvmod/
This next link is really usefull. You may want to print it and take it to your guy. They call it the "CV stud flange", if we are talking about the same part.
http://www.rockforddriveline.com/toyota.pdf
This last one is a good source for dimension, etc.
http://www2.dana.com/expert/wc.dll?DSD~dedsec~2~13~04~
I have one of these from an 85 mini that is disassembled. You would need to buy two U-Joints and the CV centering repair kit to make it complete. I can tell l you which ones you'll need. PM me if interested.
Dave
