Driver's window stick in up position.
Wayne
Bought by His blood, kept by His power
Middleburg, Florida
I have started experiencing a very frustrating thing with the driver's window. The window sticks in the up position (fully up). History note: I have replaced the window run, the regulator and motor, and the master switch group. I replaced the master switch group with one purchased from Switch Doctor and the motor is from Dorman, both about six months ago, and the regulator is a genuine Toyota replaced yesterday. I used to be able to hit the inside door panel while pressing the switch and it would go down, but no more.
I took the whole thing apart yesterday to replace the regulator. I was sure that would fix it, but no joy. I do believe it's electrical, either the driver's window switch contact is burnt or the motor is going. The motor will work in both directions when detached from the regulator and the window will go up and down when everything is hook up, but the problem occurs when the window is fully up, it will NOT come back down. HELP!
What is the inside rubber swiper doing when all this happens?
Mine will actually raise up by just a little bit and then bind tightly with the window when fully up. All I need to do is to push it down with my fingers and the window goes up and down again.
Hate, hate, HATE electrics on these kinds of vehicles.
I'd guess you have weak switch contacts. They work until they are under load.
A quick check would be to swap the two wires at the motor connector. The switch would run backwards, but it might help you learn the health of your contacts.
Also, since you said you replaced the regulator, did you reconnect the assist spring on the back side of the new regulator? They ship unattached so it can lay long and flat. I admit I put mine all together and was wondering why it went up so slow when I suddenly remembered. I took my door back apart to fix it and it all works great now.
SILVER Star, I did hook that assist spring up and I'll check the switch contacts like you suggested. Thanks.
maxamillion2345, I agree, better up than down. :)
