Drivers side window stuck in the up position.
Baton Rouge, LA
Need some help! My driver side window motor had finally died…but now I can’t get the window down to replace the motor. Anyone know how to do that?
Any one that can help, would be greatly appreciated!
You literally have to take apart the motor and track to get it out. You don't NEED to have the window down to get the window regulator out of the truck. Once you unbolt the motor, the track will move and the window will move.
It's not easy, but it can be done.
If you have not, download the FSM from the link above in the "Resources" section. It goes through step by step.
Thank you for the help! Will give it a shot today. I do have the FSM, it’s been a life saver.
"I’ll try and cut the track" ???
You shouldn't have to cut anything to remove a regulator or motor.
What have you done so far?
