driver door lock not working.
FLagstaff Az. Elv.7000ft
My wife comes in tonight and sayes that the key wont turn in the driver door lock on our 97lx.
All the other locks work fine, power locks work fine,we just cant get the key to turn in the lock.
thanks for the help.
Did it get wet and freeze lately by chance? If you suspect that, just put the key end in a lighters flame for a few seconds and then try it. Or, you could try some liquid graphite lube in the cylinder if it isn't frozen.
Sounds like car wash and then freeze to me.
Or you could have broken the little piece inside that ties it to the actuator. It is not hard to take it apart.
should have put this in my post , but this has started awile ago when out side temps were above freezing.
Then it was just kinda tricky and u would have to "jiggle" it just a bit somtimes,now it ont work at all.
Thanks for yr help.
Not that uncommon.
Just spray some WD-40 right in the keyhole. Pretty much guaranteed to take care of it.
Curtis
Yeah, just happened to me. I put some WD-40 on the key itself, ran it in and out a couple times, and it fixed it right up.
