Driveline Vibratiion Help
Chicago
I have posted this on pirate and a discovery forum without much help, so i figure I'll post here since my truck is now part toyota and you guys are always helpful?
I just swapped FZJ80 axles onto my LR Disco2, there is a thread in the 80 forum if anyone is interested. But now I have a driveline vibe coming from the rear driveshaft. I know its the rear because the front is out right now.
The FZJ80 axle has a 1" offset compared to the LR axle. It is also low pinion vs, high pinion. I never had vibes before, and now have one from 65-80mph or so.
I am running a HD aftermarket shaft from 6-states, and its got a CV at the t-case and 1310 u-joints. Since the swap we put on a new u-joint flange at the pinion end. It has not been balanced since, and think that might be causing a problem, but am not sure if a new round flange vs, the old square flange could cause a vibe like this.
Some info:
Shaft Length: 35"
Shaft Operating Angle: 15*
Pinion Angle: 15*
T-case Output Angle: 5* downwards
Horizontal Angle: about 4* calculated
Should I be vibing with a CV shaft? Any suggestions appreciated
Have you checked for proper phasing?
that means when you look down the length of the shaft the u-joints line up with each other, this can be "adjusted" where the splines come togetherif they are off by one spline they can cause vibration
good luck ...
