Driveline slop question
Redwood City, CA
Hi,
I'm trying to isolate some sloppiness in the driveline of my BJ42. I'm still learning a lot of the gearhead terms so I'll describe it as I can.
When accelerating after a stop or shifting gears, I notice a loud clunk underneath, and the steering surges a little bit to one side for a moment. The same thing happens if I let off the gas and keep it in gear, but in the reverse direction.
After reading a number of posts here on similar subjects, I tried the following. With one rear wheel off the ground and the trans in neutral, I tried rocking the wheel forwards and backwards. I noticed that there is about 5 degrees of play, and that at the end of that play in each direction the driveshaft moves a little. I then put on the parking brake and tried rotating the driveshaft, and it moves a little in each direction (not as much as the tire did though).
Does anyone have any suggestions to isolate the cause of this? Should I feel the slop in the driveshaft with the wheels braked and the trans in neutral? It is very possibly a multiple component problem, as this is a very worn cruiser and I'm still sorting through various idiot PO issues.
I appreciate any suggestions. There is a lot of great knowledge on this board!
Jack
not much help, good u-joints?? are all the bolts tight that hold the flanges together?? could be in the splines of the slip joint also, excess play on the input shaft of the diff, bad bearing.
Hi,
Jack
oh ok i just NOW read through the whole thing. i did that also. i turned the truck off and had someone stand in fron tof it adn watch as i rocked the steering wheel turing right to left and had alot of play. i was told and saw for myself that it was the shackles. All my bushings are shot so thats my issue. Sorry im not much help i know by tomorrow there will be people that are more knowledgeable here to help ya out.
like okie said....forgot about spring bushings
