Going from park to reverse or park to drive seems like there is more than normal play/slack. I had new u-joints installed in front driveshaft but have the same issue. What’s a good method to locate where this play/slack is coming from?
I also have the driveline clunk applying throttle when it is not loaded and when shifting between R P and D.
Interestingly enough mine is not present when the truck is cold, only when warm. I have checked for play in all the usual spots and can't find anything that seems obvious.
Following this thread as well.
Have the diffs been worked on or modified, auto locker?
That sounds like diff(s). If it is, I would try fluid change, maybe thicker fluid, and / or fluid modifier.
Mounts are good just had new lower case gears installedDiamond Axle Drive Flanges, cool.
How is the transmission/transfer case mount?
