Driveline Questions
Anchorage, AK
I have a vibration in my rig. Dimes to donuts it is driveline related. I do not have any lift now but I will be adding the OME 2.5 lift over the winter.
My questions are: should I just skip the BS and get some double cardan driveshafts? Do they in fact remove driveline vibration? If I get DC shafts, should I get them from Slee or??? or maybe from a local driveline repair / distributor.
Are DC shafts worth it, or am I trying to buy something I already have?
Thanks, Dennis
you don't need DC shafts usually until you are over 3" of lift, and then only normally the front shaft. If you were to put them on now, they would vibrate worse. They are only designed to operate at a certain degree, something to do with pinion angle in conjuction with driveshaft angle.
Check out your U-joints on your drivehshafts and also the slipe yokes. Most on here run a 2.5" OME lift with only caster correction bushings, no DC shafts needed.
Seconding this. My ujoints are bad and cause the vibration.
I'll say that swapping my TREs eliminated a vibration I had, as well as balancing my tires again also got rid of another vibration. There are many vibrations possible... just need to narrow the symptoms.
What i have done so far and that isn't much is replace the front u-joints. I put the phase 90 deg as I've read here, even though the FSM shows in phase.
My vibration isn't as severe, but it is still there. I'm thinking either he phase is wrong, the rear u-joints are bad or there is a problem with the motor mounts.
Cheers, Dennis
Isolate it to F or R shaft and then go from there. I am working on a vibration problem with the front.
you don't need DC shafts witha 2.5" lift. Since the truck is a 91 I'd buy two new ones from CDan and just bolt them in. I'd be really surprised if the slip yokes are any good and with the cost of U-Joints it's not that much more.
Are you referring to buying complete driveshafts? Prolly not a bad idea.
Thanks
