I just finished installing my new Slee front control arms and had caster rechecked and alignment. I have the Slee 4" lift with 1" spacer up front and my caster reading before the new arms and with the old OME correction bushes was -2.5. Now the caster is at +4 so I guess I made a 7 degree adjustment to the front axle. I might move up to the 6" springs which will bring that back down about 1 degree which would put it in the middle of the spec range of 2-4 deg. I had no real issues before with front Drive Shaft vibrations but now I have a very low frequency vib when starting off from dead stop. You can actually feel the truck sort of shudder a little and then at about 10 mph it goes away but you still can hear it when onder load at any speed. It almost feels like my old BFG M/T's did after they became cupped but these are bran new so I know that is not an issue. I noticed that the angle between the Diff and DS was reduced whild the DS to transfer was increased perhaps beyond the point it can handle. So I decided to remove the front drive shaft to see it the vibration goes away, and when I started to drive, it felt like the transmission was slipping or not fully engaged, both in drive and reverse. I also noticed that when I pulled back in the driveway and put it in park, it started to roll backwards so whatever happened, it does have a parking gear. I found where guys were talking about engaging the CDL but I don't think mine has that option. The only time the CDL lights up and is engaged is when I drop the transfer to LOW range. Will I not be able to drive without the front drive shaft installed??? Is this a normal situation or do I have something else going on?? Please help...
Mark
Mark
