I was wondering if you guys drive with you overdrive button on or off. Trying to figure out what would be best for the tranny, engine and overall driveling.
One thing to remember is that with the O/D OFF, torque converter lockup in 3rd gear is allowed. If you simply downshift from 4th to 3rd with O/D ON, you're just in 3rd gear and the TC won't lock up.
What I do, is if I'm in 4th gear and deep throttle, say enough to unlock the TC, I decrease the throttle and turn O/D off and let the TC lockup in 3rd gear. You can see the RPM increase and then drop as it goes from 4th --> 3rd --> 3rd L/U.
The difference between 4th with TC unlocked and 3rd gear with TC locked is about 200 RPM (higher). That way the transmission runs much (much) cooler as the TC isn't creating heat as it does when it's multiplying torque.
Dan.
