Drive Train Slop
Nashville, NC
I recently bought a 91 LC and it has some slop in the drivetrain when going on and off the gas. Not a huge deal, but enough to make me cringe when it happens. If I let off real slow, or get back to the throttle real slow I can make it far less noticeable. If I lock the CD, or put it in Low, (which I now know also locks the CD) the "slop" goes away. In my mind, this kind of points to the Center Diff, but I guess it could still be one of the others since they are independant when CD is not locked...
I figure if I get all 4 wheels off of the ground, I should be able to tell more about it, but was hoping someone had some insight as to what to look for once it is jacked up and supported?
If you do a search on driveline klunk or driveline slop you will get hundreds of hits and suggestions. Certainly look into it if you think it is more serious than you describe.
My suggestion is to learn to love the klunk. Don't cringe, just smile.
I did search, and what I found was a bunch of stuff about "clunking" when shifting from Park to Reverse and such...mine is more when I am actually driving...this is why it concerns me. If it were just the normal clunk when shifting, I wouldn't worry nearly as much.
Imagine that you are cruising down the highway at 55 MPH minding your own business...the guy in front of you hits his brakes...you instintively let off the throttle to get ready to slow down if you need to...CLUNK. The guy goes on, and you smash the throttle to move along as well...CLUNK.
There must be some way that I can lift all 4 wheels up and check where this is coming from, or stop one in the front from turning while I move one in the rear back and forth or something...come on you gear heads I know someone out there can help!!
No, I haven't greased the shaft "yet". I have the intake off of it right now doing some other work, as well as tune up, oil change, rad. flush & fill, basic maintenance stuff, so I do plan to grease the shaft and all of the u-joints etc. And, after reading a bit in the FAQ and some of the posts from my search, I plan to SOON repack the birfs. But this is ABSOLUTELY not a lack of grease issue. Lack of grease (or oil) may have caused the demise of some component in the drivetrain, but this is serious slop. Grease ain't gonna fix it.
No vibration at any speed (or at least any up to 70MPH...I have been scared to take her any higher than that yet...maybe after some maintenance), no noise of any kind while traveling at a steady speed...it is only present when I let off of the throttle, or when I get back in. It is slop in the drivetrain somewhere, I just need to know what is the best way to troubleshoot the drivetrain to find out where the slop is short of taking everything apart and doing a visual inspection on it.
I could certainly do it that way, and may in fact have to if someone can't point me to an easier way. I just figured that there'd be some way of telling where the slop is coming from without trial and error...
*EDIT*
By the way, I've crawled underneath and tried to "shake" the drive shafts back and forth (rotationaly speaking that is...), I don't "think" it's U-Joints as there doesn't seem to be any play there and it seems to me that there would have to be at least a little for me to notice it under the conditions that I describe above...
My $.02....sounds a lot like U-joints. Don't know of any sort of easy way to diagnose other than getting under the rig and looking at components. Good luck and post with results. BTW....welcome to the addiction!
Thanks Flash...I'm pretty sure it's not U-Joints...it's my first Land Cruiser, but not my first rodeo IYKWIM!! ;o)
The problem "feels" in the seat of the pants to be "gear related", I'm just not sure which one to break open. When I bought a '91 I knew that there'd be expense involved in getting it truly road worthy and dependable enough to make an interstate drive of 2 hours to get to the coast so I could use it for what I bought it for, but WOW, I have already spent over $500 and I haven't even touched on whatever this slop is.
I was VERY proud of my compression test though, all 6 cylinders were within 8 PSI of 145!! And, that's after 254000 miles!! So, all things considered, I don't feel cheated or anything, but a bit worried about this issue in particular. I guess I'll jack it up, support all 4 corners and see what I can see...
Mine does the exact same thing under all the same conditions. From my understanding that is just how the lc is. Remember you are taking out every bit of slack in three diffs, two driveshafts, four u joints, and two brifs. Fwiw I tore my intire Axel apart replaced both brifs and shafts, checked the ring and pinion, which was perfect, and still the slack remains. However if you find a cure I'm pretty sure it will be in the transfercase.
Transfer case was my "gut" feeling, but I have been told by the local Yota dude that in 20 years they have never been inside of one...and that they were bullet proof. Of course, I took that with a grain of salt!
I'll do some looking within the next couple of weeks, I have to work next weekend so there won't be a lot of time for awhile...
Another vote for "mine does it too"
Dude, it's normal. Trust me on this. 263,000 and mine has the EXACT symptoms you're describing. The only permanent way to fix it is to convert to part-time 4wd.
Also, trust your local Yota dude. These things really are bulletproof.
I've got the same myself; this thread is an affirmation that all is well.
After all, at 240K, it's just broken in properly. ;)
Harley - it would not hurt to make sure everything is tight and in good working order before you dismiss it entirely, but it would appear that we all share similar symptoms.
Thanks for the replies guys. I'll lube everything up, and change all of the fluids to see where it is after that. PO wasn't much of a mechanic and took it to a shop only when it wouldn't go any more...you know the type...of course, by the same token, he never did with it what I see in the pictures some of you guys are doing with yours WOW!! Of course, neither will I...it will be mostly a "beach buggy" for me, and a ride to work when it's too rainy for the Hog.
Thanks again for the info!! :cheers:
Like others have said, the clunk is a pretty normal "feature". One thing to check on older 80s is the front drive plates. On some early models, the interface between of the outer short shaft splines and the drive plate splines wears due to lack of grease. It has caused several failures over the years.
At one point was convinced this was the cause of the "klunk". Replaced mine along with a complete front 3rd member (extended warrenty). Made no difference.
Learn to love it.
Thanks Jon,
I should be able to see that when I repack the Birf's yes? I'll give it a good look over, and post back with whatever I find...but it'll be awhile yet...busy busy busy next couple of weeks...I just hope I get time to finish the shaky mirror project and put the intake back on!!
I am also quite sure this is why Tojo went with a VC center diff from 93+. I have owned my truck since I brought it home from the dealer with 12 miles on it in July of 1991 and it has always had excellent maintenance. It started to clunk at just around 40K miles. It has done so ever since. She just turned 210K. I really don't hear it anymore.
