drive shafts
Prosper TX
i recently installed a ome 4 in lift on a 97 fj-80 and im getting a vibration and a humming noise from the front and back of the vehicle i check the front and rear drive
shafts for play and they do have alittle on both would you replace the ujoints on both or would you upgrade the driveshafts?
Did you corrected the caster with bushings and/or plates?
With the castor properly corrected you will need a DC front shaft at 4"of lift. And in order to properly correct castor you will need plates, replacement arms or 4" frame mount drop brackets or a combination of 2" drop brackets and castor bushings.
I run Slee 4" wih Slee castor plates and have a smooth, quiet DC front shaft but my rear likes to growl on deceleration unless I'm loaded down and that's after rebuilding the shaft and setting my pinion angle correctly.
I run mine with Man-A-Fre caster drop brackets, OEM control arm bushings, 4.5 lift on 35"s and have no issues. The only thing I do keep the drive shafts and u joints well greased...View attachment 1213360 View attachment 1213360
