Drive Shaft Length
Cedar City, Utah
When changing drive shaft lengths due to installing a SBC using Advance Adapters components, how much of the splines at the sliding end be exposed for proper flexibility during travel. Not a rock crawler just a daily driver.
I usually measure from flange to flange and give that # to the guy at the driveline shop.
other approach is to set the slip yoke at halfway thru it's travel when the truck is sitting on the ground
Thanks. The PO had them at full compression with no room for expansion or contraction. I will get them shortened to the recommended dimension.
