drive line mystery. please help
victoria, bc
i have a puzzling problem which i am at a loss to even begin to troubleshoot. i just installed a new clutch in my 76 fj40 and everything works great, except for a metal on metal sqeal when i decelerate in gear. is there greater pressure on the driveline on decel vs. accel? the clutch does not slip. i can squak my 33s on dry pavement and gas it up a big hill with full performance. and when i am slowing in gear there is also no sign of slip. could the problem be coming from the e-brake, which has been showing signs of wear lately? the t/o bearing is definetly not engaged on the p/p when not in use. and the pilot would squeal all the time when the pedal is out if it was pooched. anybody out there able to touch this one?? what have i done wrong?? :confused:
You are not really giving us much to work on here. Your questions are likely to be answered with more questions such as:
Did it make this sound before you messed with the clutch? If not, then it's possible something you did caused the problem. Did you put the clutch disk in correct? Did the TO bearinng have any noise or roughness? What was the condition of the the pilot bushing? Did you have the flywheel resurfaced??? Did you even install the correct parts?
If all above OK then this may not be your clutch as I would reason the clutch would be more likely to slip on acceleration than deceleration. What is the condition of your TC? Third member? Maybe a worn TC center/idler shaft, bearing or thrust washers?
Follow the sound and isolate the problem.
ok. yeah, my first post was pretty muddled.
this noise wasn't present before changing the parts. in fact, it wasn't present at all on my first test drive after installing the clutch. so it could be another problem that has just become apparent making it SEEM like its the clutch. i did also adjust the rear brakes.
my main thing is: why would something in the drivetrain make noise on deceleration and not on acceleration? this confuses me. what changes? i was hoping someone out there might have experienced the same thing and could point me in the right direction
you're right, though. ultimately i've just got to source the noise and get on it.
in my paranoid mind i am concerned that might have happened. but i know i checked and double checked, like i always do. is it really possible to put the disc in backwards and have everything bolt up nicely?? the splined sleeve that fits over the trans input protrudes more one way than the other. i always assumed that if it were backward the longer side of the sleeve would hit the flywheel and not sandwich nicely b/w it and the p/p....
Glad to hear you found the problem. I am pragmatic so the source of the noise has usually steered me in the right direction. Easier said than done I know.
