Did oil changes on manual gearbox, transfer case, and rear diff today due to it being a sunny warm day before wet weather returns
I'd never paid much attention to it before, but the drain and fill plugs on each are not the same.
On the gearbox, both fill and drain plug are the older flat head style and don't have any washer. Drain plug is not magnetic.
On the transfer case, fill and drain are the newer chunky head style plus the drain one is 19mm head not 24 mm.
On the rear diff housing, fill is newer chunky head while drain is older flat head but is magnetic (and has a metal washer).
Dunno about the front diff as I didn't have time (or enough oil) to change it's oil today.
I see that having the flat-head drain for the diff housings makes sense as the head is then 'protected' by the formed ring welded into the housing.
The old oils all looked not very nice but only the rear diff oil looked 'wierd' (can't describe it properly).
I'm presuming all drain plugs (not sure about the motor sump) should probably be a magnetic type? Does it matter for gearbox and transfer if they are older flat head or newer chunky head type?
