drain along driver side body
Purcellville, VA
I recently moved and have been parking my rig on an inclined driveway. It has been raining quite a bit and I've noticed a "sloshing" sound after hard rain after I pull off the driveway. I did notice that there has quite a bit of water coming out of the drain on the driver side directly under the driver front door when I stop at a stop sign. It is not the door drain but appears to be a hole/drain on the body basically at the center line of the front door....
I don't see any wet carpets or water along the A Frame, window frame, floor, etc.
- Is this normal? Or, do I have a leak somewhere that I should be concerned about? Any idea where the water (under normal conditions) comes from that drains out there?
Thanks.
The sunroof drains into the rocker panels. You probably need to get out a zip tie and clean the slots in the rockers to remove the debris stuck in the slots, slowing the draining. At the bottom of the pinch weld, slightly on the inside, under the truck.
Look carefully at the seam along the bottom of the rocker panel. You will see IIRC four D-shaped openings stamped into it where the seam comes together. You'll likely find the back ones plugged up with mud or other grunge. The front one seems open. You park at an angle and the rocker fills up, then you leave and the water pours out the front drain opening once you're more level than the parking spot.
Take a large tywrap tie and poke the slim end up through the D-shaped opening. That should unblock it, so watch out for it soaking you with rocker panel juice...
