Drag link bent from locked steering
Hungary - CA
Incident / symptom:
During an outing last weekend, I was not able to steer left at all, the truck would just go straight. Not like if loss of power steering but a total seizure, not even a hair. By steering the other direction the ability to steer either direction came back. But during the trail inspection, I noticed the steering stabilizer was badly beaten and the drag link (the bar with TRE's from steering box to the PS knuckle) was bent badly also. The steering would not lock up for the rest of the weekend and also removed the stabilizer and drove home 200+ miles on highway without a hitch. By the way, there was no obstacles on the trail which were keeping me from steering (in case somebody thinks I was just plain dumb:)
What I am not sure of:
- I am not sure if the drag link was already bent before the steering lock.
help - Information needed:
Aside from repllacing TREs, steering stabilezer and drag link - what other parts of the steering system should be checked/replaced? Could the steering box have an intemittent problem? Luckily this happened in 4 low at low speed. If steering locked like that during highway travel, I would be attending my funeral.
Thanks for the help.
I bent mine bad recently. It was slightly bent from a previous incident/run which I believe helped to make a nice U shaped relay rod.
First hit:
Result:
I just ordered a heavy duty relay rod and tie rod + ends. I don't believe there is anything else to worry about.
My first thought is to wonder if one of your birfs locked. I've never heard of it happening in such a way as to lock the steering- it usually causes the birf to explode, but maybe you got lucky. What's the history on your birfs? Have you serviced them, and if so, were they worn at all? Don't get excited, this is idle speculation on my part, just trying to think of what would cause the steering to lock.
As for repair, I've repaired my steering links by simply pressing them straight again. That requires removal, and of course a press or access to one. Replacing them with heavy-duty hardware is also an option. I wouldn't bother with paying money to replace them with stock though- straightening them would do the trick. On my rig, the suspension components are so close together due to lift that I'd worry about having enough room for the larger diameter links.
-Spike
My steering "locked" also, because I couldn't turn the wheels. I could however turn the steering wheel. That is what caused the bend to worsen. I read Mickey's post as the same thing happening. I didn't think the steering wheel had locked. But I might have misunderstood.
From what I understand, guys that were looking under my truck when trying to move, said the relay rod would bend, then straighten with my wheel movement. With that kind of movement, I feel safer with beefier rods.
Re-reading Mickey's post, he says the steering was straight when it locked. In my mind that pretty much rules out the birfields being involved, especially if the truck was moving at the time. No other ideas from me.
-Spike
First hit:
Result:
wow - mine has that exact bend in it - we are bent link brothers - I am speculating that I had an initial bend as well.
It felt locked. And I was pretty much moving straight, and then had to turn to the left. That is when I could not turn. We stopped, but may have not noticed the bend yet. Then I moved again and turned right then left and then it worked again. I am scared of the birfield locking up. I did service my left birf just before CM07 but did not have time to do the PS. The DS looked good fine. The rig has 237K miles on it and major services were performed at the times thay should. My friend suggested the steering box. I also checked the PS fluid and there is only very minor sweating - no leaks etc. Well after I get the parts and put it together I will have to trail test it again.
Pretty sure it was your relay rod bending, then straightening. You probably straightened it out enough to get going again. The pitman arm 'pushes' the relay rod to turn right and 'pulls' to turn left, thus, turning right will bend, left will straighten if your wheels aren't responding.
My steering felt really 'mushy' when this was happening.
I don't think your birfs or power steering caused this. Beef up or replace the rod(s) and get new ends (added insurance) and you'll be fine.
Mickey I have seen first hand how you beat that truck. Toyota made a fine product with the 80 series but your truck sir is genetically gifted. I am surprised this is the first time you bent your rod.
I sleeved my rod recently with tre change. you should do the same. An ounce protection is worth a keystone
I am truly amazed that it bent after 237,000 miles of severe service (well prolly should take off the ~ 50k when it belonged to the dentist). Anybody that ever asks me what 4x4 to buy - I tell them, buy an 80 series because I am pretty sure i would have broken everything else into a million pieces by now.
so while it was bending - I had no left turning or the re-bending was feeling like no steering? - makes sense in some weird geometrical way.
Sounds like it.
I had no steering to the right (bending), then no steering to the left (straightening), UNTIL the relay rod was straight enough to actually do something.
I hope that helps and doesn't make it more confusing. :confused:
Talk to wrench,
He tried to tie his like a pretzel at CMCC.
FWIW, If memory serves The final solution was to hit the offending rod (removed from the truck) against a tree. Personally I bought new ones from Christo when I bent mine.
Wat worries me is wrench lost the ability to turn to the right when he bent his, not the left.
Dave
i ordered christo's drag-link on monday - but he was out of tre's so i ordered those from marlin - the tre's are all the same thread for the tie rod and the drag link? if i remember they are different thread diameter
Different thread diameter for tie rod and relay rod. relay is 12mm tie rod is 14mm IIRC. Talk to Bud at Budbuilt.com. I have his tie rod and drag link after bending 2 OEM ones in 1 season. These have been on the truck for several years and have taken some pretty good shots without complaint.
