Downstream Oxygen Sensor
Colorado
I'm getting a code 28 in my 93 FZJ80. It looks like that's listed as a No2 Oxygen Sensor. I'm assuming that No2 refers to the what the repair manual calls "downstream." (I haven't been able to get an original FSM yet, I'm using Haynes.) I've been reading all the threads about O2 sensors, but when I go to buy the parts I'm confused. At Rock Auto and Parts Geek, all the oxygen sensors are listed as "upstream", none of them are "downstream" or "No2". Autozone lists a "downstream" but on the forums it seems like it would not be advisable to buy Bosch from Autozone. Does anyone know if the upstream sensor will also be used downstream? Thanks for your help, I'm learning a ton from the forums, I appreciate all the knowledge here.
There are no downstream O2 sensors on the 93 & 94 models. They have 2 heated sensors side by side with each one monitoring a bank of cylinders.
The 93&94s are finiky when it comes to O2 sensors so best to stick with the OEM - Toyota does a kit with 2 sensors which is good value.
Thanks, I'm assuming it's just best to replace both at the same time?
On the 93 and 94 they are both upstream, referred to as bank 1 and bank 2. There are many threads on this you can search. Also there are links to an electronic version version of the Factory Service Manual several times in the past few days.
Did this fix the code for you? I just got code 28 in my '93 yesterday...
Yes and No. It pointed me in the right direction, but I haven't been able to replace my sensors yet. The old posts holding the sensors on are too rusted and corroded to get off. I've been putting off taking it to a muffler shop to get their opinion and help replacing the sensors. If you replace yours successfully I'd be curious to hear if it clears your code.
