Downey Bellhousing - Starter Options
RWBeringer4x4
Mechanically Challenged
The People's Republik of Maryland
Hey all -
I'll be upgrading from a Lakewood bellhousing to one of Downey's sometime in the near future. As luck would have it, my starter also just started squealing at startup.
@Downey - your manual calls specifically for a cast-iron nose cone starter.
1. Does anyone know a part number for an iron-nose starter motor? They seem to be getting pretty tough to find...
2. I read somewhere you could use a "high torque" starter with no nose cone with the AA setup. Will this work with a Downey setup as an alternative? Any brand or part number recommendation for this one? What does it bolt to?
For what it's worth - I'm currently running an old 283 SBC. Never looked to closely at the starter but I imagine it might be a cast iron nosecone, as its from the right era...
Yup, your 283 would hav come with the cast-type starter.
I know Jim is gonna poo-poo me on this since it was good enough for OE spec, but the hardware for mounting that starter always made me shudder. Speaking from the experience of having sheared the 3/8 starter bolts on my 350 more than once, those bitty bolts for the 3bolt set up were, pardon the pun, a non-starter for me. IOW, when I installed one of Jim's bellhousings at my shop, I cut it out until I could mount the 'standard' two bolt starter to the block.
Best
Mark
Hey Mark,
Thanks for following up! I'm sure I can go look at the truck, but does the 283 have the mounting holes in the block for the standard 2-bolt stater?
Just curious, since I'm getting very used to finding missing bolt holes since the 283 is now officially ancient. The most obvious example is the lack of mounting points on the heads.
Also - how much cutting is involved?
Here is the underside of the starter. Looks to me like I'm currently running a block-mount version, which makes sense because I believe the Lakewood scattershields were used to mate up automatic transmissions...
And some shots of the top:
Looks fairly aluminum to me!
In case anyone stumbles across this in the future, this article is really useful:
http://rmcavoy.freeshell.org/starters.html
I'm pretty sure I NEED the first nose cone mention, but I HAVE the aluminum, staggered 2-bolt version.
Lastly: looks like RockAuto might still have a few rebuilts in stock.
@Downey and @65swb45 is this what I'm looking for if I don't want to do surgery on the bellhousing?
REMAN:
More Information for PURE ENERGY 3635S
NEW:
More Information for WPS / POWER SELECT 3686N
Although I've never heard of world power systems...
In case those links go dead, and for posterity, here are some alternate part numbers listed by RockAuto:
Alternate/OEM Part Number(s): 3635, 3686, AH76330, TY1454, TY26035, TY6693
Looks like there are also braces that mount to the front of the starter, to take some pressure off the nose cone. Maybe I'll add one of those while the engine's out.
Yes, the above starters are what you want. I'd only poo poo on Marks comments because I never had the problems he mentions. I also believe someone makes the smaller high torque starters in the 3 bolt configuration, which would fit the Downey bellhousing.
So basically, as long as has the correct bellhousing bolt-pattern, it'll work.
I highly recommend the starter brace for the gasser motors. For the 6.2 and 6.5 GM diesels this brace is of extreme importance as the starter motor is a high torque unit, and can break the block (destroying the block) if not used.
Don
Looks like Summit has a high-torque option:
http://www.summitracing.com/parts/pwm-3635/overview/make/chevrolet
Plus a couple of OE replacement options as well (for $$$) - not sure if high torque or not
http://www.summitracing.com/parts/wgl-3686n/overview/make/chevrolet
http://www.summitracing.com/parts/wgl-3633n/overview/make/chevrolet
Looks like the cast-iron nose cones are not that hard to find once you know what to look for...
@handcannon - any reason to NOT go to a high torque starter on a gas engine? I'm not going to be running the diesel. Per our many previous conversations, sticking to the 283 if I can, or going to a 350 of some sort (roller vortec or flat tappet) depending on the 283's condition.
out of curiosity
since the Downey bell housing mimics the Lakewood in respect of being a full circle housing, why are you changing?
out of curiosity
The lakewood setup, apparently, was a "drill your own mount holes" deal. I'm pretty sure mine is not mounted straight. Several of the bellhousing bolt holes are stripped. Plus, I have absolutely no idea what amalgamation of Chevy and Toyota parts are housed inside. I decided a while back to go with a complete Downey setup (since he had one laying around) so I knew when I pulled all the current stuff out, exactly how to make what I put back in work properly.
The lakewood setup, apparently, was a "drill your own mount holes" deal. I'm pretty sure mine is not mounted straight. Several of the bellhousing bolt holes are stripped. Plus, I have absolutely not idea what amalgamation of Chevy and Toyota parts are house inside. I decided a while back to go with a complete Downey setup (since he had one laying around) so I knew when I pulled all the current stuff out, exactly how to make what I put back in work properly.
A perfectly reasonable explanation. The Downey bell housing, like the AA, is VERY accurate for locating the trans. And the mounting holes are reinforced. My mind initially glossed over that.
Yeah, I should add, the @Downey bellhousing was just too damn sexy ;). Plus, he has helped me out with knowledge and answered my amateur-hour questions countless times over the last 3 years, and even picked up some parts from you to deliver to me. Both of you are totally awesome dudes and I try to throw money at you whenever I get a chance! :beer:
Last question goes back to what @handcannon mentioned - what's the difference between "high torque" and standard starters? Does "high torque" provide more torque, or is it capable of SURVIVING more torque? If it's a matter of survival, upgrading to high torque seems like a no-brainer. If it provides more torque, I'm not sure it's really necessary.
High torque= smaller, spins faster, on less voltage. I like them because they make for easier starts on carb'd vehicles, AND because I can use the gear reduction to MOVE the vehicle in technical terrain at a lower speed than the powertain.
Help----hoping @65swb45 and/or @Downey can give me some guidance....
You can scroll down to technical part of question, and skip this background bit about how I got here.....
Bought a '68 with my son. 3 on tree was difficult for him, so went to floor shift. Still had problems in traffic with 3 speed....everyone mad at him for being slow....put 33 inch tires on it to get some rubber overdrive, now the drums needed a block to stop, which to a 16 year old trying to still figure out this 3 speed thing is ...not good. So we decided to start gathering parts for 4 speed upgrade and disc brake front axle. At our pace we weren't sure if the old gal would get out of the garage in time for his graduation. So we went looking for a suitable "driver" that we could play with while the '68 was down. Found a '76, priced right for a temp solution. One owner.....but had spent time on east coast so rusty. He had just spend thousands of dollars getting the swapped out sbc 350 rebuilt, but had gotten sideways with the mechanic when the starter wouldn't engage properly and said mechanic wanted another 2000$ to fix it....I come along and figure it probably needs shims or.....and I can fix it's other issues and we can can a school daily driver.
Technical part:
SBC swap with Downey bell housing. Starter on passenger side. Starter typically takes 10-15 attempts before it engages flywheel. When I crawl underneath, one of the 3 mounting holes has been cracked off. The starter does not fit snug to the bell housing. So I'm guessing a mechanic wanted 2K$ to take engine back out, weld on bell housing....
With this situation, in light of this being our temp solution, I don't want to pull engine etc....and I don't have anyone to weld it in place....would the best solution be to get a mini-starter and do what Mark did---mount to the block? If so, in particular mini-starter brand/model, and where do I "cut"
Thanks for any help you can give
