Double trouble with Intercoolers
Perth, WA, Australia
Hey everyone, my first post here. I currently have a naturally aspirated 1hz 80 series in great need of a little more giddyup! Now I'm still researching turbo end (I'm building a hybrid ct26 7mgte) but that's not what this post it about.
Now I live in Western Australia where during summer you want your cooling system in tip top shape, so naturally with my turbo set up I want a good Intercooler.
There seem to be three main options when it comes to the intercoolers, front mount air to air, top mount air to air or water to air.
All seem to have benefits and drawbacks, I've listed the few I know below.
Front mount air to air:
Drawbacks - uses lots of space and custom installation can be a pain, lag time, less to no cooling at low speed without thermal fan set up (not sure how useful viscous fan is here) and possible restrictions to radiator air flow.
Benefits - no heat soak issues, awesome for long term and high speed driving, good cooling capacity, simple, no extra systems to maintain.
Top mount air to air:
Drawbacks - less efficient cooling, heat soak, thermal fab requires power (another system to maintain in an otherwise simple set up).
Benefits - thermal fan constant air flow even at low speeds, easy to install, doesn't take up much space, good excuse to graft on an awesome 76 series bonnet scoop, cheaper due to less pipework.
Water to air:
Drawbacks - heat soak over time (can be resolved with greater coolant capacity?), another relatively complex system to maintain, if turbo let's go water could potentially get into the engine (yayyy for hydrolock.....).
Benefits - much more efficient cooling depending on quality/size/location of heat exchanger and pump set up.
(Now I'm sure there are many things I've missed or gotten wrong so please feel free to correct me or add to what I know, I'm no expert yet)
Now here's the part which hopefully separates this post from any other intercooler thread. Has anyone tried using two or more of these cooling methods in one set up?
For example a front mount Intercooler with a water to air Intercooler plumbed somewhere in its rather bountiful pipe work?
If this post doesn't generate much interest I'll be even more inclined to give it a crack myself a post my findings here :)
Cheers all
I've not used an intercooler on any 80. But I have owned trucks with both types. The difference in heat soak is minimal between the air and water overall. I think the folks who have issues with the water are under sizing the water system based on bad Internet advice.
When space is at a premium the water IC is perfectly capable when sized correctly. Stacking 2 water ICs would be simpler than the Air/water combo you propose. Use the largest reservoir you can fit. Buy a high quality pump $$.
If you have the space for Air/Air no need to add the complexity of water.
When crawling at low speed you generally not boosting much either.
So the concern regarding front mount A/A for me is almost none.
If a concern add an additional electric fan.
Keep it simple.
I think dual coolers just add additional flow restriction and could create lag.
Also depends what you going to boost. The ct26 is a small turbo but a good match for the 1HZ.
Add a good EGT probe to the 1HZ with turbo and manage your EGT's.
