double checking igniter wiring
South Pierce County, WA
Yet again I ask the board for help. I would appreciate if someone or more would check this out and holler at me if I have it wrong before I fry something. I've swapped a 78 2F into my 66FJ40, using 78 electronic dist, a coil and igniter that doesn't seem stock compared to the Haynes manual, but Jim C. said it was ok when he saw it with my carb and dist rebuild and it sounds like what most folks describe.
So far, I have this figured out I think.
Red and white wires-plug-from ignitor to dist.
Black/white from starter solenoid to + coil.
Aftermarket tach to - coil.
Green ground wire from igniter to bracket which is grounded to fender well.
Here are the questions.
I read a couple ways to address the yellow wire and the tan wire which end in another shorter plug. On this igniter, the yellow side goes to + coil and the tan goes into the igniter.
Will it be workable to make a "Y" at the black/yellow wire that is swithced 12v from wiring harness, take one side to each prong of the plug on the igniter that the yellow wire and tan wire come from? Seems this would split the current to igniter and coil.
OR... Would it be better to to put switched 12v to + coil and make a jumper wire from + coil to tan side of plug? This would ignore the yellow wire. Seems to me this does the same thing. I just need to understand if switched 12v needs to go thru the igniter before reaching the coil?
Another question. There is a condenser/resistor thing on the end of a 3" wire that looks as per Haynes to goffrom ground at bracket mount to + coil. Is this correct?
Thanks tons for all your help and time!!
The colors you describe don't jive with the Toyota wiring diagram for '78, so maybe it is an aftermarket ignitor. The stock colors are:
Black/yellow stripe: switched power
Black: from ignitor to coil
Red: From distributor to ingitor
White: Distributor/ignitor ground
White/black: Chassis ground.
Without knowing where the wires go to the ignitor, it is hard to make a guess about which cassis wires to connect to them. Both the coil and the ignitor have to get power from the ignition circuit. The ignitor needs the full 12 V from the switch, but some coils (and not others) get a lower voltage because they have a ballast resistor in series with the ignition wire.
The condensor is for suppression of radio frequency noise and goes from the + side of the coil to ground.
What you describe sounds like what I see. Maybe I'm just not stating it clear enough. There is a black from igniter to - coil that I forgot to mention and the green that you don't mention is to the bracket only. The white/black chassis ground is probably the one with the resistor on it. It has heat shrink on it and I don't know what color it is. You don't mention the yellow or tan wires that come from the plug.
I've decided to come from the black/yellow stripe wire that is switched 12v, splice it to the yellow and tan wires that were in the plug. This should feed the 12v switched power to the coil and igniter as described. The igniter says Toyota on it and the coil denso. I can only assume they are 78 as they came with my 78 engine. Of course they could be from anywhere. Is there a way to tell which had the ballast resistor? If this doesn't have one then I think I'll be ok. If it does will it fry? Should I put a fusible link in that side that feeds the coil just in case? Thanks for your help!
White/black stripe is a chassis ground on all toyotas and would not have a resistor in it (ever).
Maybe yellow or tan is what they look like now, but Toyota didn't use these colors. Try peeking under the insulation to see what their original colors are.
If the two wires that come out of the plug go to the ignitor, they both don't go to 12V, because you only need one connection.
Since you have a black/white stripe wire that goes to the + side of the coil from the starter solenoid, this bypass wire indicates that you should have a ballast resistor. This is consistent with the schematic for '78 that also shows a ballast resistor. The ballast resistor is a rectangular metal box on top of the ignitor that is about half the size of a pack of cigarettes. One end of the ballast resistor connects to the + side of the coil (in addition to the black/white wire). The other end of the resistor connects to the black/yellow key on wire along with the power lead from the ignitor.
If you have a ballast type coil, you need to run the ballast resistor or the coil will overheat and eventually burn out. A fusible link won't help and Toyota didn't think it was a good idea.
See '78 schematic here:
http://www.yankeetoys.org/documents/wiring_diagram_78_fj40.pdf
HTH
