Door switch replacement ideas?
Hillsborough, NC
For some odd reason, both of the switches in my rear doors have gone bad. When the doors are are opened, they do not turn on the dome lights or the 'door open' indicator on the dash. This means that anyone getting into the vehicle when it's dark via the rear doors does not have the benefit of George's LEDs.
I pulled out both switches and sprayed them down with contact cleaner. Only the rear USDS door switch started working in one brief point on the plunger travel but the USPS side refused to respond to treatment.
Is there any way to refurbish or replace these switches? It's not obvious how they can be removed w/o losing the wire lead inside the door cavity then I'd be really screwed.
I'm really befuddled as to why the rear door switches would fail before the front doors, maybe lack of use and the contacts have corroded. Any ideas on how to fix a worn-out door switch?
P.S. I can short the lead at the switch to the opening in the door jamb and the dome lights go on, so I know it's not something in the harness.
You can find this stuff at Radio Shack. It is relatively expensive and comes in a pack with 2 small spray cans. It is good stuff. You only use a small amount.
BTW, there is another connector on those rear door switches. It is behind the panel in the cargo area.
-B-
