After several months wrapped in blankets, it was time to finally hang the doors which were already painted. Got the driver side on before I realized that the body shop had not welded new ears for the stop to connect to. They had addressed the rot by welding a plate in the area where the ears used to be but no ears. I went to my machinist/fabricator with an idea and here are the results. His work was perfect as usual whereas my cutting will require a little patch and paint. He made the angle of the ears to match the passenger door and welded to the plate. I drilled and tapped for 5mm and then pulled the works through the door with a length of wire so it didn't end up in the bottom
of the door. Cheers
Tom
of the door. Cheers
Tom
