Right, I was forgeting my mantra earlier...."It's always the alarm".
PS. I'm not seeing the diagram you posted???
I followed the one from the rear door and it seemed intact in the wiring harness.
- Back hatch - no dome light, but dash indicator lights up.
Checked - the alarm had a cable running to the FRONT right (driver's) switch.
Not sure about the '91, but if you you look at the diagram above there are 3 other paths to +12V leading to that door switch. (through the other lamps)
A burnt door courtesy light should not affect the overhead light....if the bulb is burnt out inside the door then the overhead light will not receive power?
Not on a '95. The front and rear doors are isolated to their respective lights....does every door when opened illuminate both interior dome lights?
I never received a fob with my Cruiser, and I hated the auto-lock feature when starting it, so I removed the alarm.side note;
have you and trouble with key fob?
You remove the ignition kill relay too. See my post in this thread: Alarm frustrationnow if you just removed the entire factory alarm was there any issues with starting? id imagine if the alarm was disconnected and removed then theres no way for it to send a signal to the ignition to disable the start.
have you installed an aftermarket keyless lock/unlock or do you just live with inserting the key in the door?
