Door actuator replacement from eBay
Replaced my passenger side actuator on my lx450. I choosed the 20mm shaft actuator on eBay . Removed the gear on the old shaft and put it to the new one then soldered the wiring on the actuator . So far so good. A really cheap fix if u have the time .
Can you post up the Auction Title or Auction # from Ebay.
Nice Work!
Thank god. I've been trying to figure out if those would work. Thanks!
This should be stickied btw
The gears are a little loose on the shaft I used a kwik set JB weld . Just a dub so it won't get messy . Also the body of the actuator is a little tight on the casing . You have to push it in by your thumb and it latches really good.
