done!!
I'm at 75K miles, but I've got a '94, so I figured it was time to replace some of the electrical stuff --
-- well, what a JOY this was -- really -- not a toughie at all -- I used the Bosch Platinum x2 plugs -- I wasn't about to pay $14 per a Denso Iridium plug if I still have to replace it every 30K miles --
-- the air tube (crossover) was a bitch to get back on -- one thing, when I had the new plugs, wires, rotor and cap on, I tried starting my truck, partially disassembled --- it wouldn't start -- the PCVs must need to be plugged in --
-- also, it's odd, when the engine's at idle and I open the oil fill cap, the revs go down reaalll low, like it's gonna stall -- when I put the cap back on, all's okay -- I'm sure there's some odd theory to that, but I don't know it --
-- anyway, an enjoyable day with my cruiser -- I even cleaned up the engine bay a bit, too... :) :) :)
eric
Eric,
The crankcase is sealed, removing the oil cap creates a vacuum leak. Having the PCV valve unhooked creates a huge vacuum leak.
As you don't have many miles this might not be a concern but next time you service plugs you might want to check valves, replace the valve cover gasket and sparkplug tube gaskets. I don't know if the sparkplug tube gaskets get old with time or mileage.
kurt
