Done with this high idle problem
Orlando
Website
www.ishamonline.com
Ok so i did the o ring, then went to washers and still startup idle is much higher and slower to drop than any car i have ever owned. I just hate slamming it into gear at 1600 rpms every time it sits for a few hours... Has anyone just replaced the ISC valve? To me it worth the money just to not have to worry about it anymore... Dan what do you think?
In case your wondering I am referring to the start up idle issue, not idling after warm up which is perfect.
Gabe
My ISC was disabled (connector missing a couple of pins) when I bought my 93, so there's never been a high cold idle that slows as it warms up. The idle was around 1200 all the time, so I decided to take the ISC apart and adjust it by hand to get the idle speed down to 800 or so. I have no problems with cold weather, and neither should you in Orlando, so it's an option until you give in and buy a new ISC. The ISC also idles up when the A/C is on, so that function is out the window, too.
Adjustment was just a matter of turning the magnetic portion which moves the valve in/out, installing, and checking the idle speed. I marked every point on the magnet with the rpm at that setting so it'll be easy to change, if that's ever needed.
Just an FYI from a poor bastage that can't afford a new ISC. :frown:
For $10 in chemicals and a gasket, I would suggest pulling your throttle body off and giving it a thorough cleaning. I had the same problem for a year and was getting ready to buy a new IAC. The hose side of my TB looked fine, but the intake side was nasty. The small runners that flow air past the IAC were particularly bad. Once everything was cleaned and reassembled, the idle returned to normal and was noticeably smoother. This is a :banana: at most.
I would recommend doing this as well, but I didn't notice a difference in start up idle. One thing that did drop my start up idle considerably was installing a "tuned" new blue fan clutch. That took about 300 rpms off the start up.
my TB has been cleaned inside and out when the HG repair was done. It still idles way up to 1600 and sits there for 5 minutes before it comes down, start it cold with the a/c on and it will hit 2000... even warm i have to turn off ac before i start it or it will jump way up.. i see a new iac in my near future.
Blue fan clutch installed weekend before last.
i sure have not- i will look in the manual tonight- but i can assure you if it involves meters and voltage and all that stuff i usually close the book pretty quick.
LOL I hear you man! While it does involve all of the above, its a pretty quick test. Usually it takes more work to get the two screws out than to test the IAC. I think there is a pretty good thread around here about testing and cleaning the IAC.
EDIT: Here you go...
Testing it: https://forum.ih8mud.com/80-series-tech/213654-testing-iac.html
Cleaning it: https://forum.ih8mud.com/80-series-tech/193319-iac-vss.html
