Domelight Placement
The West
hi im looking for pics anyone has of the dome light placement of the 1973 and up hardtop verses the 72 and down and if you can change the dome light placement without cutting or welding up any wholes.
and just pictures of the inside of both types of hardtop
thanx, Rachel
Rachel, IIRC, the dome light changed in 9 of 73, at the same time as the jump seats. Not only did the placement change, but so did the actual fixture.
The older ones mounted via a bracket that shared two of the bolts that hold the roof panel and side panel of the hardtop together. It mounted above the raingutter flange.
The 74 and newer ones had three holes drilled in the pillar post behind the front door, two for the attachment screws and one for the wire.
Hth
Mark
Hth
Mark
thanks man, thats some good info. where can i find pics of this . im a visual learner :eek:
