So I have traced down my battery drain problem to the dome light. When all the doors are shut, all the lights are off. But there is still a drain going through the dome light circuit. Here is how I found out.
1. Pulled off the positive battery cable
2. Put test lamp in series between the battery terminal and the batter cable. The test lamp is now on because of a closed circuit.
3. Pulled all the interior fuses. Light is still on.
4. Starting pulling all the exterior fuses in the box on the DS finder.
5. When I pulled the dome light fuse, the light went out. All doors are still closed.
So the question is, with all doors closed and the dome lights are out, what could still be draining the battery on the dome light circuit?
Thank you for you help.
