Dome fuse keeps blowing
'93 fzj80, aftermarket head unit, factory amp bypassed. Truck will not stop blowing the dome fuse. It started a couple months ago, blowing every couple weeks, now I put a fuse in, turn on the head unit, and it pops. Before turning it on though, I get a ton of interference through the speakers that varies with engine rpm.
This is driving me insane, anybody have any idea where to start? I've checked the usual suspects, and have gotten nowhere.
Sounds like a bad ground, or a crossed wire. The interference is a big red flag. Check the the main power wire and the switched power to insure no breaks. Remove stereo, does the fuse blow? If not, use a mulitmeter to check voltages. Then go through and connect wires one by one until you find the problem.
uhhhhh... pull your head unit..... answer should be there
I forget what is on the same circuit as the dome lights but agree. Pull your head unit. Sounds like you pinched something there and its now grounding out.
Assuming you are using the factory wiring/connectors the power for the head unit comes from the dome fuse, so no surprise that is the fuse that is blowing if you are having troubles with the head unit or amp.
You said you bypassed the factory amp. I assume this means you pulled the connectors (S11 and S12) out of it. If not, I would definitely pull them out - maybe your problem is somewhere in the factory amp. If they are already pulled and are floating, confirm that you don't have a short there.
If all is good around the factory amp circuit/connectors, like others have said in this thread, I would pull the head unit and start troubleshooting back there. Could eaily be a crossed wire or a floating, unused wire from the head unit shorting out.
Take a look at the attached pic of my aftermarket Kenwood. The installer clipped all the wires he didn't use, then taped them together. If you have a situation like this, you might find your problem there.
Been pulled about a dozen times now. Factory amp bypassed, factory sub completely removed, re grounded the unit, have gone through all wires for the HU and found nothing. Ill put it back together, and it works fine for a while seemingly until it rains(but not always) then it blows. Take it apart, check it out, and all seems fine. This is what has me stumped. If the grey plugs are not used, does any power flow through the factory amp?
if it only blows when your radio is turned on, you have a problem with your radio. If it never blows unless your radio is turned on, you have a problem with your radio.
do you normally have your head lights turned on? you may have inadvertantly wired your illumination wire and used it as radio ground. remember that all toyotas use white with black stripe as ground.
I suppose i could have been more clear, but it does not always coincide with the h/u, just now that appears to be the main issue as I cannot power it up without popping the fuse.
If you've pulled the radio a dozen times - make it a bakers dozen and get your radio +12 from a diff circuit- leave the dome circuit to itself- report back
Ended up having nothing to do with the head unit. It was a bad harness coming off the under hood fuse block. It was intermittently shorting out. Putting the stereo on its own circuit would have solved nothing.
Hey there. What was your solution? Replace the whole harness?
